Konica c7000 Error Code C-1272
  • CopyTech03
    • Jul 2020
    • 54
    [Error Code] Konica c7000 Error Code C-1272
    Has anyone come across this code before? It refers to the trimmer in the saddle stitch unit. Had the customer run the books without trimming, but it still codes after a few books.
  • raplma
    • Mar 2017
    • 139
    Re: Konica c7000 Error Code C-1272
    No, and we have had said machine and finsiher for years... but to get the ball rolling in case SM is not to hand...
    2.11.2 C-1272
    Code
    C-1272
    Classification
    SD: SD-506 abnormality
    CauseCorrectionSolution
    1. Check the trimmer paddle, and clean/repair it if any abnormality.
    2. Check the connector connection and the wiring between SDDB and the motor, and repair it if any abnormality.
    3. Check the I/O drive of the motor and the coupling of the gear, and repair/replace it if any abnormality. (Wiring diagram: SD-506: 11-W)
    4. Replace M33.
    5. Replace SDCB.
    Faulty part isolation DIPSW
    DIPSW7-3
    Control while detached
    The use of the trimmer unavailable
