Bizhub C224e hoe to reset password to default
  • ck1
    • 485
    I have one unit c224e 2nd hard machine . but the CE password is change and unable to logon . how to change to default password ?
  • rrrohan
    • Sep 2011
    • 1976
    Re: Bizhub C224e hoe to reset password to default
    U can bypass the ce code or atleast you use to.
    If it throws up a C error code while it's at the password screen when you click ok it dumps U into service mode without password. Then just initalize everything
    Or get password reset code and put in an escalation to have password reset code generated by KM.
    But they don't do this for end users
    Sent from my Pixel 4 XL using Tapatalk
    • ck1
      • 485
      i try the ce password request code but still can't reset it
      • drowranger
        • Jul 2015
        • 122
        have you tried default x2y2 two and four times ?
        Only other way is to use the mfp reset A145FW.TAR.tar file if you cannot get the reset code from km to work.
        Please use a 4gb usb v2 on the fw port if you use the reset tool.
        Good luck..
        • ck1
          • 485
          Good luck..
          i try 9272 X2 and x4 still same .the a145fw.tar inside only index file right 1kb only ? reset code is machine provide or need send to km ?
          • drowranger
            • Jul 2015
            • 122
            Hi it is 1kb only. copy it to the root of usb . you will see reset complete msg on the screen once its complete usually takes couple of seconds.
            once reset done please use a normal runup procedure and make sure to change time or you can makes copies with lines of shame. enable hdd and set adf ect.
            • ck1
              • 485
              Thank work
