Bizhub 227- RESTING OZONE AND TONER FILTER
  • Franco107
    • Nov 2020
    • 16
    Hi guys,
    Is it possible to reset the ozone and toner filter of a Bizhub 227. I did tried counter reset but didn't reset filters.
    Appreciate all your response in advance.
  • rrrohan
    • Sep 2011
    • 1977
    Re: Bizhub 227- RESTING OZONE AND TONER FILTER
    Originally posted by Franco107
    Hi guys,
    yeah in life counter. if your just clearing it you should probably also clear the transfer roller as well as all 3 trigger at 150k
    • emujo2
      • Mar 2017
      • 1579
      Filters are one thing, and def cleaning and resetting the counter is acceptable, but I would not recommend resetting anything else involved in print quality that has not actually been replaced. The machine bases it's corrections on life counters. E
      • tsbservice
        Field tech
        • 8020
        True anyway not on filter counters
        • Franco107
          • Nov 2020
          • 16
          I'll replace the filters.
          Thanks for your time.
