C450i Colour Drums
  • stan780953
    • Feb 2011
    • 47
    C450i Colour Drums
    Hi,
    Just wondering if anyone has tried using a black drum to replace a colour drum and if this has been reliable in the field. The C450i black drum doesn't fit but a black C250i fits ok with a couple of adjustment similar to the 8 series and there are chip available.
  • thanakon1995
    • Apr 2021
    • 8
    Re: C450i Colour Drums
    I have not tested If you have a chance, try to test.
    • Gift
      • Mar 2011
      • 2413
      Thanks for the tip with the BK C250i drum - we use C308 BK drums but what we do is probably way more work, because you have to harvest different parts from the i-series unit.
      • sam_engineer
        • Oct 2021
        • 1
        Hello - currently need to replace the colour drums in a 450i.. can you give me more info on how to use the C308BK drums? Appreciate your help and tips.
        • Gift
          • Mar 2011
          • 2413
          The differences between the units are mainly the rear cover + charger roller contact and the waster toner auger (differnet length) + nozzle thingy and - if I remember correctly - that "gearish" thing on the back on drum shaft plus that spacer. Chips from 8 series work, too. You can either harvest a C308 drum in order to refurb a i series unit (the quicker way) or strip the necessary part from the old i series drum and refurb the C308 drum and make it fit (the more thorough way). Whatever you decide, it is more work compared to COL->BK mod for the 8 series. I think the price gap between the 8 BK drum and i series BK drums do justify the effort.
          Depending on the routine the time amount might be 10-30min/unit
          Best thing is to mess around with some used units from the "bin department" in your shop first...
          • flippinsweet
            • Oct 2013
            • 34
            Thanks for the info Gift
            I've just refurbed a C308k drum with parts taken from a used C250i colour drum which I need to fit to a C450i machine. Swapped the rear cover, charge contact, drum gear and front section, also snapper off the plastic stopper on the right hand side and fitted a new colour chip for the 8 series.
            I've done this before but never had to fit to a C450i and noticed the part numbers for 450i / 250i drums are different. Do you know if this should work or if I'll need to swap the waste toner auger & nozzle you mentioned? Don't have any 450i drums in the office to play about with unfortunately!
            • Coggers
              • 17
              Hi where did you get the drum chips from ?
              uk based and we need these chips.
              • splblazer91
                • Jul 2014
                • 204
                I havent had luck with swapping i-series drums. They always seem to background.
                • tsbservice
                  Field tech
                  • 7635
                  Please specify what you mean by swapping?
                  • splblazer91
                    • Jul 2014
                    • 204
                    Replacing an i series color drum with an i series black drum or vice versa.
                    • tsbservice
                      Field tech
                      • 7635
                      Only drum cylinder or you modified whole drum unit(ie making from black colour like 4 and 8 series) but it backgrounds?
                      Sorry for maybe asking too much questions but it has some specifics you know.
                      • avecosat
                        • Jun 2012
                        • 298
                        since series 8 you can't swap color drums to black ones without making some changes
                        • Gift
                          • Mar 2011
                          • 2413
                          The chips are the same as Cxx4, Cxx8
