C450i eat toner
  • jwai
    • May 2018
    • 508
    C450i eat toner
    now i have one C450i consumed toner abnormally.
    one new Y toner only used approx 3 days and less than 10k copies.
    the waste toner bottle are filled with Y toner.
    I checked that a thin coating on the surface of Y drum, the TCR ratios are all 6.XX%.
    The ATVC of C M are 20, K is 22, Y is 16.
  • Synaux
    • Mar 2012
    • 1224
    Re: C450i eat toner
    Meter on Y IU?
    • allan
      RTFM!!
      • 5462
      Re: C450i eat toner
      25K @ 5% coverage.
      12.5K @ 10%
      7.25K @ 20%
      Could be that they are printing heavy coverage yellow?
      Check coverage history.
      Reset coverage counter...
      Whatever
      • jwai
        • May 2018
        • 508
        Re: C450i eat toner
        Originally posted by Synaux
        Meter on Y IU?
        the color counter is 120K something and 25K on black.
        • jwai
          • May 2018
          • 508
          Re: C450i eat toner
          Originally posted by allan
          25K @ 5% coverage.
          12.5K @ 10%
          7.25K @ 20%
          They mainly print some office document such as word, excel, autocad.
          the color ratio on printout is quite low.
          • allan
            RTFM!!
            • 5462
            Re: C450i eat toner
            Ask them if what they printed over that time. Could have pushed some kind of flyer or marketing document.
            Check coverage report anyway
            Print a Y half tone @50/255 on a healthy machine and compare it. If its dark then it could be low main charge or even developer.
            If i cant see anything else wrong i would try and increase the value of the yellow background adjustment to +3 and TCR on Y to -1/-2.
            That would push more charge and decrease toner concentration. Then wait for the call to return or not, or next toner delivery.
            When it comes to aftermarket toner yellow is the worst!
            Reset the values when replacing the Y drum/dev.
            Whatever
            • jwai
              • May 2018
              • 508
              Re: C450i eat toner
              Print head, would be the cause I guess?
              • allan
                RTFM!!
                • 5462
                Re: C450i eat toner
                No that would be a visible defect. I'm out.
                Whatever
                • jwai
                  • May 2018
                  • 508
                  Re: C450i eat toner
                  Nowadays I can't print half tone test print from defective machine.
                  The machine shows add toner Y and stop color print, I installed a new Y toner and remain has this warning screen after 5 minutes of auto toner replenishing.
                  • allan
                    RTFM!!
                    • 5462
                    Re: C450i eat toner
                    Change the drum unit... from Y to C or M to test if problem stays on Y or moves. Or just change it. Are you using original toner?
                    Whatever
                    • jwai
                      • May 2018
                      • 508
                      Re: C450i eat toner
                      i changed them for test , same result. i used genuine toner.
                      this day i poured a bit toner and got auto replenishing with blocked the ph window, after the tcr raised to 6.8%, i check the drum it got clean.
                      however the tcr of c and m dropped to 0.0x%, took the manual add toner the ratio raised to 5.x%.
                      got a bird test print the background have a slightly pink, checked the transfer belt there had a m toner coating, and the machine showed p5 p6 p8.
                      • tsbservice
                        Field tech
                        • 8004
                        Re: C450i eat toner
                        Check back of machine for blocked/clogged with toner air ports. Don't remember if this C450i has toner filter at the back of machine check it could be full of toner also.
                        • jwai
                          • May 2018
                          • 508
                          Re: C450i eat toner
                          yes, i had cleaned this filter, dirt with Y toner.
                          after cleaning the Y section seems better, just hard to understand why both C and M developing section have problems after the Y toner replenishing.
                          • Gift
                            • Mar 2011
                            • 2459
                            Re: C450i eat toner
                            Had a similar issue because of a faulty hv board - even the developer was drained in that case.
                            On out first attempt we just swaspped the dev unit but the issue re-occured and then we
                            swapped both the dev unit and hv-board.
                            I think it was on the 8 series but also a brand new unit.
                            • jwai
                              • May 2018
                              • 508
                              Re: C450i eat toner
                              For me it's the first time I visited on console machine.
                              The Y toner got empty only 3 days and a bit thousand text and lines printout.
