toner bottle chip
  • jwai
    • May 2018
    • 509
    toner bottle chip
    dear all,
    sometimes the toner bottle chip has problem, the toner near empty message still stay and color bar doesn't reset to full.
    there have any solution to fix it on machine other than replace another new toner or change the chip?
  • allan
    RTFM!!
    • 5462
    Re: toner bottle chip
    Search CTN there are SW settings for that.
    Whatever
    • tsbservice
      Field tech
      • 8020
      It depends on model. 7,8, i series have it.
      • jwai
        • May 2018
        • 509
        soft switch have? let's check it~
        • jwai
          • May 2018
          • 509
          Thank you for your prompt, I found on 7 and i series.
          I can't find them on 8 series S/M, they are same as 7 series?
          • Gift
            • Mar 2011
            • 2459
            I think it's better if the chip detection is off because the customers usually call in the issue and if you have many service contracts including toner you have at least a chance to explain to the customer that they have to wait until the actual toner-end condition pops up. Otherwise up to 20% of the toner is thrown out of the window. Ignoring this is like draining all remaining gas from your car before filling it up, most customers get this analogy
            • jwai
              • May 2018
              • 509
              I consider that design on 4e series is better.
              • jwai
                • May 2018
                • 509
                usually customer changed another new toner to fix it, the original one would be placed as spare.
                • tsbservice
                  Field tech
                  • 8020
                  No. Without chip things are worse.
