bizhub 600 "Now Warming Up Ready to Scan Some Time Ready
  • manzoorwighio
    • Dec 2019
    • 28
    Bizhub 600 Show Now Warming Up Ready to Scan , Some time Ready , Or Some time Show Error C2801
    I Also Tried to Clean Sensor TCSB But Same Problem
  • tulintron
    • Jul 2014
    • 668
    Re: bizhub 600 "Now Warming Up Ready to Scan Some Time Ready
    Description
    Intermittent "Now Warming Up" message.
    C-28xx error code may also be indicated.
    Copies/prints may be "gray".
    Copy/print jobs not being output, stuck in job list.
    Engine list prints cannot be output.
    Solution
    CAUSE:Machine isfailingtocomplete a DMAX/Gamma check. Dirty/failed Toner Control Sensor Board and/or possible failed PRCB.
    SOLUTION:Check Service Call Countersfor excessive counts.Clean or replace the Toner Control Sensor Board (p/n 56AA -910 2E). Replace the PRCB if
    necessary (p/n 57AA-902 1J). Perform drum peculiarity adjustments.
    • Bricorley
      • Jul 2017
      • 41
      usually new thermistors will fix the warming up issue
