Hard drive format!
  • Assaf
    • Jun 2009
    • 59
    Hard drive format!
    Hello Team
    Can you format the HDD from the device it self? Do you know if the models below can all be formatted via the panel?
    Thanks in Advance!
    368E
    458
    C368E
    C659
    368
    C658
    C368
    4050
    C3351
    C558
    C287
  • tech51
    • 846
    Re: Hard drive format!
    Yes.
    • patrickjlc
      • Feb 2015
      • 225
      What model? I think 454/554/364 you can format from the screen. You might need the movie data files later.
      Sent from my motorola one 5G UW using Tapatalk
      • emujo2
        • Mar 2017
        • 1579
        Each of these devices can use either the control panel or service mode to format the HDD. E
        • tsbservice
          Field tech
          • 8061
          Hey guys you see #2 post? Already answered
          • Assaf
            • Jun 2009
            • 59
            Thanks Everyone!
            Do you know if the device print some kind of confirmation after this been done?
            • emujo2
              • Mar 2017
              • 1579
              Formatting the HDD, no, but doing a overwrite (mode 1-9) yes, with a caveat..If your firmware is out of date, the report will not print on any device with over the life consumables. But if you have everything updated, or past the f/w level required for this, then yes, you can have a report generated at the end that shows the HDD wipe was done. E
