Portuguese firmware for BH 284e
  • ltdiniz
    Supervisor de Campo
    • Mar 2021
    • 98
    Good night !!!
    I need the firmware in Portuguese for BH 284e_224e
    My equipment has FW A61F0Y0-0100-G00-C8
    What would be the Portuguese version?
  • emujo2
    • Mar 2017
    • 1579
    Re: Portuguese firmware for BH 284e
    Originally posted by ltdiniz
    Good night !!!
    From my experience, changing the marketing area gave you the different languages..and there is not much difference..
    If you set the marketing area to US, spanish is available, (again I don't know if Portugese is the same), but the paper default is LT LEF, changing to others 5 would still give you US and Spanish as a selectable language, but A4 LEF is the default paper size. Also changing the marketing area may put your consumables into an over life condition...E
    • ltdiniz
      Supervisor de Campo
      • Mar 2021
      • 98
      Thanks for the tip!!!
      My client's problem is that due to the same being Brazilian, he wanted a Language on the Panel with PT to facilitate the operation of the user functions, I thought I had a FW Language for this BH284e model.
      • emujo2
        • Mar 2017
        • 1579
        I believe the language selection options are under utility/user/system settings/language..There are also language selection in the driver. E
        • Walterj
          KONICA MINOLTA
          • Jun 2017
          • 89
          Good night !!!
          good day
          When rewriting the FW it gives you the options to choose the languages ​​you need to appear in the user interface (operation panel).
          If you require any version of FW you can write to me at walvaradocruz@gmail.com
          Greetings.
          • tsbservice
            Field tech
            • 8081
            Originally posted by Walterj
            good day
            Greetings.
            I think Walterj is correct. I was going to write the same.
            • emujo2
              • Mar 2017
              • 1579
              good day
              Greetings.
              That's good info..after 20 years I've never used the language portion on a f/w update..Good to know. E
              • ltdiniz
                Supervisor de Campo
                • Mar 2021
                • 98
                • tsbservice
                  Field tech
                  • 8081
                  Try another FW plus yours is old FW version.
                  • ltdiniz
                    Supervisor de Campo
                    • Mar 2021
                    • 98
                    ltdinizudia@gmail.com I appreciate it.
                    • avecosat
                      • Jun 2012
                      • 305
                      The last firmware with portugues language is G20 - M0 MSG99
                      • ltdiniz
                        Supervisor de Campo
                        • Mar 2021
                        • 98
                        Exactly this version Solves my problem with the Portuguese update.
                        Whoever is this Firmware my e-mail and ltdinizudia@gmail.com and I am willing to negotiate values or in exchange for documentation and firmware that may be available.
                        • rogermatsunaga
                          • Aug 2021
                          • 1
                          Hi, guys!
                          I'm also searching for this FW in portuguese or latest version.
                          Itdiniz have you already found it?
                          • tulintron
                            • Jul 2014
                            • 668
                            Originally posted by rogermatsunaga
                            Hi, guys!
                            Itdiniz and Rogermatsunaga, this line of black equipment was not sold in Brazil. There is no Portuguese update for these models
                            • ltdiniz
                              Supervisor de Campo
                              • Mar 2021
                              • 98
                              Really Tulintron this model was not sold in Brazil I know that but I believe that KM has made a base update PT in some FW Multilingual in the update pack, but by the way this version doesn't even exist in PT.
                              But since already thank you!!!
