C558- ERROR CODE- C6756
  • Franco107
    • Nov 2020
    • 16
    Hi guys,
    I have uncounted this error after solving the squeaking noise from the fusing unit.
    I used a CRC spray and lubricated the fusing gears and it got rid off the problem(squeaking noise),however, after running some tests,an error occured,C6756.
    I tried downloaded the latest firmware, did continuity test on the DCP, re-connect all cables but the problem still persists.
    Please HELP me solve this issue.
    Thank you in advance
    Best Regards,
  • tsbservice
    Field tech
    • 8053
    Re: C558- ERROR CODE- C6756
    This code means: CCD power-supply voltage malfunction.
    Did you tried trouble reset procedure?
    • Walterj
      KONICA MINOLTA
      • Jun 2017
      • 89
      Originally posted by Franco107
      Hi guys,
      Best Regards,
      Good day:
      Dear, I recommend you do the following
      Correct the harness connection between CCDB CN5-SCDB CN5 if faulty.
      2. Correct the harness connection between CCDB PJ5-SCDB CN5 if faulty.
      3. Correct the harness connection between SCDB CN1-DCPU CN5 if faulty.
      4. Correct the harness connection between SCDB CN1-DCPU CN005 if faulty.
      Measure the ICP of the Scanner drive board (SCDB)
      Check the connections of the MFPB, the right side all that wiring you have to verify
      • hechterw
        • 6
        Hi guys,
        Best Regards,
        Hi Franco107
        Did you find a solution to your fault?
        I am currently having the same issue as you -without the CRC spray and lubricant.
        Please advise
        awaiting patiently for a response.
        hechterw
