c253/353
  • konica
    • Sep 2025
    c253/353
    Does any body know where i can get the image unit chips reset for this model.
  • JSC
    Gimp
    • Dec 2006
    • 618
    I wouldn't bother, just set the iu life to suspend in tech rep, you can get up to 50% more life out of the units ( depending on how the machine is being used ) by which time they will need changing anyway.
    The gene pool could use a little chlorine.
    • techhead
      • LAKY
        • Mar 2009
        • 16
        chip is reset by Katun
        • ni311
          • May 2008
          • 658
          To get more life from the unit, the Normal/Suspend Mode should be setup while the imaging units are new. You cannot get rid of the annoying message "please replace..." without a new unit or chip.
          Can you give us a link to Katun with their reset?
          Konica Minolta Error Codes - Explanations and Solutions
          • LAKY
            • Mar 2009
            • 16
            Copier parts, imaging supplies, photoreceptors, service accessories and printer products from Katun
            laky
            • ni311
              • May 2008
              • 658
              yeah, thanks, we all know the site, but can you give us the link to the actual resetter?
              • D Colour
                • Oct 2008
                • 217
                As far as i know, these chips can not be reset. You need a brand new set of chips. Katun doesn't have the machine as of yet. I know Parsia International are expecting these chips into stock this month.
                These guys here are also expecting them this month (although i have only learnt of them this morning!)
                Copier Chips Ltd | Suppliers of Imaging Unit Chips
                Everything that has a beginning, has an end.....
                • Bizhub
                  • 147
                  I have heard of this company too and it looks like they are going to be cheaper than Parsia. Lets see who gets out there first !!
