problem c 6500
  • LAKY
    • Mar 2009
    • 16
    problem c 6500
    I have a problem with the glossy 300g
    is a center line as in Annex
    thanks
    laky italy
  • random
    This black only? Turn THICK BK mode on.
    Colour? Make sure paper grain is short and maybe set second transfer pressure to low.
    • LAKY
      • Mar 2009
      • 16
      c 6500
      and secondary transfer 'was positioned low, this problem also for colors,
      This problem only occurs with paper 300g
      thanks
      laky
      • ni311
        • May 2008
        • 658
        What is the counter of the machine?
        Konica Minolta Error Codes - Explanations and Solutions
        • LAKY
          • Mar 2009
          • 16
          c 6500
          the problem is evident on all types of machines installed both new and used
          thanks laky
          • kmcopier
            PSP
            • Oct 2008
            • 183
            Check your belt line speed, also there is a special technical information for this
            • LAKY
              • Mar 2009
              • 16
              c 6500
              as technical ?????????
              • Gleq
                • Feb 2007
                • 72
                Does it occur before fixing if not manually adjust the fixing rollers tension. thanks
                • random
                  In this case it is probably long grain stock.
                  • Si@danwood
                    • Mar 2008
                    • 154
                    Im afraid they all do this!!!!TSG in uk advise that this is the limitation of the Engine.Adjust the second transfer offset may help but not a great deal
                    • Setright
                      FSS / SPM
                      • Nov 2008
                      • 247
                      I agree, this does look normal
                      Try increasing the amount of coverage, and consider using "rich black".
                      • sbillis
                        • Nov 2008
                        • 95
                        How do you turn THICK BK mode on and what you can achieve with that please?
                        It is also apply to c5500,c5501?
                        thanks
                        • redhotrob
                          • 69
                          I'll agree. I've tried to remove this myself, changing every setting I could when a customer using a C5501 complained about it. Tested several machines, all did it.
                          • LAKY
                            • Mar 2009
                            • 16
                            c 6500
                            talking with konica minolta milan told me that this problem and 'limits of the machine and depends on everything from Japan, and meanwhile the competition (xerox canon) makes
                            hello laky
                            • mecanico
