C5306 on Bizhub 658e
  • SAR
    • Jul 2009
    • 203
    This code has been popping up intermittently for months on this copier(according to the service history). I haven't seen this code at all on any model, so I just wanted to see if anyone has come across this issue before and what fixed it for you?
    This is a refurb copier we have in our shop, so I have the time to try some different parts on it. The service manual mentions replacing FM7, the EXCB, or the MFP board.
    Before I start throwing parts in it, I wanted to see if anyone has seen this?
    So far I have updated the firmware, done a data clear and formatted the HDD. Came in this morning, turned it on and it coded out again.
    I'll be sure to post up the fix if I don't hear from anyone.
  • elmaligno
    Expert technician KM
    • Oct 2009
    • 302
    I have changed some of those fans because of noise or slow running, that causes them to bring up the fault code. They are usually in an area difficult to access for cleaning and do not ventilate well or simply fill with dust on the blades and are damaged.
    Field technician since 1994
    • SAR
      • Jul 2009
      • 203
      It ended up being a bad fan. I was surprised how cheap that fan was($9 US).
      Thanks for the heads up elmalingo.
      • tsbservice
        Field tech
        • 8031
        Which one?
        • SAR
          • Jul 2009
          • 203
          Which one?
          It was the IH coil cooling fan FM7.
