Disabling Papercut
  • Valintine
    • Jan 2012
    • 147
    Disabling Papercut
    Hello
    The boss just bought a Bizhub C458 to refurb. I found out it has papercut. Does anyone know how to uninstall or disable this? I usually work on Toshibas but the boss seems to be pushing the Konica Minoltas lately. Any help would be appreciated.
    Joe
  • blinxwap
    • Jun 2020
    • 80
    Re: Disabling Papercut
    Originally posted by Valintine
    Hello
    Joe
    Anyway i know how is to remove the printer from the papercut server and then turn it off on user authentication
    Sent from my Hisense U40 using Tapatalk
    • tsbservice
      Field tech
      • 8082
      You may want it starting from fresh. Enter service mode, system 1 - Initialization - clear all data. You will need to re-enable HDD and install Movie data though.
      • Valintine
        • Jan 2012
        • 147
        When I power the machine on it tries to connect to the papercut server. Shortly after it comes up with a message timeout. Nothing happens when I press the menu button. Is there something else I need to do to enter service mode?
        • blinxwap
          • Jun 2020
          • 80
          Follow trouble reset procedure once it popsup the key pad will display then go into service mode and initialise the mc
          • Valintine
            • Jan 2012
            • 147
            Thank you for the help. When I opened the front door to turn the machine off something told me to press the menu button and I was able to get into the tech rep mode and it is resetting now. Again thank you for the quick help. Have a great day.
            • emujo2
              • Mar 2017
              • 1579
              If this does not solve the problem you can go into the open API settings and remove any registered applications. E
              • rrrohan
                • Sep 2011
                • 1977
                if you press access it takes u to the standard user auth login screen, from there u can press menu then counter and so on
                • tsbservice
                  Field tech
                  • 8082
                  Yes Papercut won't prevent to enter CE mode.
