C3100P imaging unit chip
  • jwai
    • May 2018
    • 508
    Hello,
    Last time I replaced the chip of K imaging unit due to end of life and it succeed.
    This time I did so, however, the machine displayed K imaging unit is missing.
    I tried 2 more chips the same result occurred.
    So what's the reason? and any setting on tech rep mode can release either toner or IU chip cannot be detected normally?
    Best regards,
  • CP-1015
    • Nov 2020
    • 318
    Re: C3100P imaging unit chip
    Bad contact!
    • jwai
      • May 2018
      • 508
      I replaced back the current chip, it displayed back IU-K life end.
        • 14709
        It sounds like you are using the wrong chip. Is that possible?
        • jwai
          • May 2018
          • 508
          I ordered the chips from taobao, I tried them and all displayed IU-K is missing.
          Long Long time ago I got the same chip and reset the IU successfully.
          • CP-1015
            • Nov 2020
            • 318
            If there are wrong chips, isn't there another error?
            • jwai
              • May 2018
              • 508
              only " IU-K is missing " displayed......
                • 14709
                If you have a new IU install it. Then send the bad chips back and order some new ones
                • CP-1015
                  • Nov 2020
                  • 318
                  I thought it displays not "missing k-unit" but "wrong unit". But it seems it's a wrong chip.
