KM bizhub c368 Sata Controller Error
  • Jinn
    • May 2023
    • 134
    Hi,
    Error code : C-D011
    Have replaced 3 working HDDs,
    Disabled HDD but it gives error code C-D072.
    Tried repairing by updating sata controller firmwares but machine stays on 3 pillars.
    Not taking any other firmware.
    Not taking reset file. Tar
    any solution?
  • z3tech
    Konica Minolta Tech
    • Oct 2023
    • 9
    Is this the FW you are using?
    Recovery Tool firmware
    A7PU0Y0-F000-GXX-A8
    GXX-A8
    An error code CD010, CD011, CD050, or CFA14 may occur on any of the MFPs listed above. If this happens, you will need to use the recovery procedure
