Bizhub C3351
  • antone
    • Oct 2014
    • 344
    Bizhub C3351
    TROUBLE CODE C6751...REPLACEMENT of scanner unit also MFP....boots up and still TROUBLE with same code! Also fuser warms up ...but control panel says warming up. List prints o%%%
    Sent from my SM-N981U using Tapatalk
  • emujo2
    • Mar 2017
    • 1579
    Re: Bizhub C3351
    have I mentioned in any earlier thread about how much I hate these POS??? That code is a CCD gain adjustment failure. you have to replace 1/2 the machine to fix it..Any chance the new scanner was tested before you put it into the machine? I have had so many used come in that didn't work it's laughable.. Scanner and finisher issues, what a complete hunk of crap..E
    • tsbservice
      Field tech
      • 8020
      Re: Bizhub C3351
      After replacement of scanner unit did you try trouble reset?
      • Brett GS
        • Jun 2013
        • 154
        Re: Bizhub C3351
        The old B42's did that a few times too me and had to replace mfp boards.
        • Flash
          • 378
          Re: Bizhub C3351
          Check the connector for the ribbon cable. You have to push down on it to lock it.
