BH-C-280, K only?
  • Hansoon
    • Sep 2007
    • 3350
    BH-C-280, K only?
    Customer upgraded his machines but want to keep one of his old BH-C-280 for B&W mono copying and printing only.
    I know that one can adapt the operation panel display for copying in K only and also there are K only drivers but he wants to be sure that nobody ever can make color copies and prints with this machine.
    Question: Is it possible to limit this C-280 to B&W only? Any mysterious soft switches making this possible unknown to me?
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
  • tech51
    • 846
    Re: BH-C-280, K only?
    If it was me I would put a password on it and default that to greyscale only print and copy. Job done…
    • tsbservice
      Field tech
      • 7917
      Still machine will eat color toners and drums slowly. Calibrations are unavoidable.
      Other than that you can go password/user authentication way or just like you said plus I would prohibit USB print.
      • tulintron
        • Jul 2014
        • 669
        Hans
        You can put the printer as preferred black and hide the option in DIPSW.
        https://www.copytechnet.com/images/smilies/cool.pngNada como dia após diahttps://www.copytechnet.com/images/smilies/cool.png
        • jotunn
          • 595
          Replace CMY toners with K (change caps), after ~200 A3 prints, you've got B/W machine
          • tsbservice
            Field tech
            • 7917
            Did you tried this personally?
            • Hansoon
              • Sep 2007
              • 3350
              Had to laugh first, cause sounds funny, but are you serious.........?
              Cannot imagine that the calibration pattern being only in in K on the TB will be accepted by the logic of the machine. Furthermore operating costs are not only coming from toner use but also the drum and developer being used.
              Hans
                Hans
                Paper and electricity.
                Wear n tear.
                • jotunn
                  • 595
                  That was just for fun and confuse
                  No, it will not work (at least in this machine | there are other ways for this machine), but not for the reason you think of:
                  IDC sensors are color blind, they just measure density of the pattern, and doesn't matter what colour the pattern was printed.
                  So the important thing is location of the pattern (there must be toner patch in correct location on TB) and its density.
                  You can change the order of color developing units to prank somebody, but remember to block toner pipe (to not contaminate with other color) and make only few copies.
                  All K toner will not work for this machine, because of difference in develping units build, and conposition of the toners.
                  Black toner has additional developer mixed, for developing unit life extension, so there is a difference in developing unit (and waste toner box) for developer recycling.
                  Color developing units was designed for much shorter life, so they doesn't need recycling pipe and additional developer mixed with toner.
                  Without developing unit modification, the additional developer would kill them in short period of time.
                  __
                  The easiest (and not funny at all) way is:
                  - set [Image Stabilization Priority] -> [Black]
                  - set DipSW to hide Color option for copy
                  - use B/W driver from Bizhub 224 if you don't need user authentication
                  or
                  - use normal driver, set B/W for default
                  - block color prints for authenticated users
                  • Hansoon
                    • Sep 2007
                    • 3350
                    So the "density" of a K patch will be the same as for a Y patch???
                    This was not my intention ofcourse. I do this occasionally for testing purposes
                    Yep, I got that
                    __
                    Where to find which DipSw. And yes I'm stupid and on top of that lazy too.....
                    The driver is the easiest solution and has been done here for years.
                    or
                    On all our machines we install at least two drivers. One for color, one for mono and often too for duplex and letterhead also
                    I HATE the configuration for that authentication stuff. Did I tell, that I'm not only stupid but lazy too??
                    Thanks for your input.
                    Hans
                    • tulintron
                      • Jul 2014
                      • 669
                      __
                      or
                      you were expert in your explanation
                      • jotunn
                        • 595
                        Yes.
                        Laziness has made us human
                        DipSW 71 hex 02 - should hide color selection buttons from user screen
                        You can also set DipSW 50 hex 01 - ACS mode control set to black prints (1st transfer roller CMY retracted)
                        • B0265
                          • Jan 2007
                          • 718
                          Yes.
                          Have you verified this yourself?
                          I did not expect the reflected light from a 100% K patch be the same as from a 100% Y patch.
                          • jotunn
                            • 595
                            Density measured by IDC sensors is not the lite reflected from the patch, but light transmitted through the patch and reflected from the background (transfer belt).
                            Amount of light reflected from clean surface of transfer belt (even if its surfrace is not really clean due to wear, toner contamination etc.) sets the current "background level" and density 0%
                            The machine produces set of 8 patches per colour, read the IDC sensor output voltage for each patch, then approximates linear function of gradation.
                            The patch which transmits the least amount of light (within the set range of boundary values) _IS_ the one with highest density (but it doesn't mean you can get 100% K)
                            For sure, the black toner absorbs more light from IDC sensor than other toners, but that's enough for approximation and calculations needed to output acceptable prints.
                            • Hansoon
                              • Sep 2007
                              • 3350
                              This is for an Indy not being able to go to KM-class, good solid information, thanks!
                              Hans
