Bihub C558 Error "Currently Character Recognition cannot be used"
  • darknet93
    • Nov 2015
    • 89
    [Misc] Bihub C558 Error "Currently Character Recognition cannot be used"
    Hi good day everyone.
    i have 1 unit bizhub C558 that have error "Currently Character Recognition cannot be used" i believe it is because of OCR Data is not installed. which i dint have it.
    can i know where to get it ?
    i do have the PDF/A data , movie data & Voice data for this model but OCR data i dont have it.
    and actualy i also already try to deactivate the i-option function for this unit by login into the " https://lms.konicaminolta.com/license/KM/support.aspx "to request the activation code. after login and request t?he deactivation code base on machine serial number i got error " unable to confirm setting " does anyone know why ?
    This gallery has 3 photos.
  • rrrohan
    • Sep 2011
    • 1977
    ocr.zip
    • darknet93
      • Nov 2015
      • 89
      Originally posted by rrrohan
      Thank you for the OCR data. just now i installed it but the error " Currently Character Recognition cannot be used " is still showing. any idea why ? or is it my data for PDF/A Font is wrong ?
      This gallery has 1 photos.
      • rrrohan
        • Sep 2011
        • 1977
        What firmware and function version?
        • darknet93
          • Nov 2015
          • 89
          I'm sorry but im not so good with Konica. is this helping ?
          This gallery has 9 photos.
          • mascan42
            • Oct 2008
            • 484
            Firmware's up to date, but check the device info screen for the function version. It should be v 4.2. If not, update dipswitch 25 to B0, then reboot.
            • darknet93
              • Nov 2015
              • 89
              Hi... okay my function version is 4.2 and my dipswitch 25 i check by default is A0 then i change to B0 and reboot. but the message " Currently Character Recognition cannot be used " is still showing on the screen. any more idea that might help ? thank you...
              • darknet93
                • Nov 2015
                • 89
                As a last way i can think, i end up by changing this sata flash M.2 which i believe is the counter board. i take from my scrap machine.. after change then upload back the movie data. the machine now is running well. but i'm still curious if there is a way to fix this issue.
