Problem in Graddation Adjust C454e
  • andrecopfac
    • Feb 2020
    • 17
    [Misc] Problem in Graddation Adjust C454e
    Hello friends.
    I have had problem on 4 C454 machines and all related to not capturing paramtersnumbers in Graddation Adjust.
    I reset the developers and imaging units. I've also changed the developing powder, cylinders and image belt.
    Has anyone caught this problem?WhatsApp Image 2021-08-12 at 09.29.54.jpgWhatsApp Image 2021-08-12 at 09.29.54.jpg
    Re: Problem in Graddation Adjust C454e
    Originally posted by andrecopfac
    Hello friends.
    Has anyone caught this problem?[ATTACH=CONFIG]49927[/ATTACH][ATTACH=CONFIG]49927[/ATTACH]
    Are they using genuine KM supplies?
    Have you cleaned the density sensor?
    • JR2ALTA
      • Feb 2010
      • 2033
      KM doesn't sell developing powder for these, only full units. So I am guessing not OEM.
        Hmmm then that might just be the 'fly in the ointment.
        • andrecopfac
          • Feb 2020
          • 17
          We use developer refills to replenish used amount, and toner we use 8000 refills. I've already cleaned the belt sensors too
            It's been proven that 3rd party toners/ dev powders cause all sorts of problems due to the fact that the formulations are exactly the same as genuine OEMs.
            • tulintron
              • Jul 2014
              • 668
              Here in Brazil, many equipment used C8000 toner as a refill.
              This is one of your big problems.
              Report the life of your supplies and the toner being used.
              Thank Konica Minolta for end of life toners for the Bizhub C8000.
              Owners buy and technicians suffer.
              • tsbservice
                Field tech
                • 8009
                Hello friends.
                I meant not likes but ask what's your bird page looks like?
                What errors you have are they only odd values in gradations?
                • avecosat
                  • Jun 2012
                  • 305
                  Make a Initialize + Image stabilization first and all image settings
