di 470 fp115 question
  • brent
    • Nov 2008
    • 1186
    I am having 2 of my machines give me paper jams. it is definitely out of the 3rd tray. replaced both feed and take up tires. and sep assy. then the motor. it is very intermittent and frustrating. it will copy like 50 or 60. then jam. it actually is not picking up the paper out of the tray. then all the sudden it will work. but it is double and tripple retrying. you can watch the copies on the finisher tray and they are slow coming out. minolta has been not very helpfull to me on this. and I am a dealer.. anyways if you guy's have any thoughts that would be appreciated. by the way. both trays 1 and 2 are working properly..
    brent
  • rocky246
    • Feb 2007
    • 91
    Have you tried replacing the one-way clutches? Replace or clean them and scuff up the shafts. Good luck!
    • brent
      • Nov 2008
      • 1186
      I will get the parts manual out and take a look. to be honest I have had very little problems with these and have not had to go beyond the feed and sep tire replacement. I will take a look
      thanks
      brent
      • rocky246
        • Feb 2007
        • 91
        Both clutches are located on the gold colored roller.
        • brent
          • Nov 2008
          • 1186
          I am printing off the parts manual now. I can't seem to figure out where you are referring to. do you have a part number? man do I feed dumb
          brent
          • brent
            • Nov 2008
            • 1186
            ok I have found them. I will check. it is the white one way right next to the feed roller. I will check or just replace. thanks for your help
            • rocky246
              • Feb 2007
              • 91
              There are two. They call one a gear, but it has a one-way in it.
              #4002-3217-01
              #4002-3203-01
              • brent
                • Nov 2008
                • 1186
                rocky. just a quick update. I ordered the parts shaft and 2 one way bearings. and thus far it has made a huge difference. not jamming and working perfectly. for some reason I thought it was a motor problem. but I am really glad it wasn't. just wanted to thank you for your help. I really appreciate it. another one fixed!!!!!
