Hello,
I am at my wits end with this.
I am faced with the EXACT (in every aspect) same problem as this poster did:
https://www.copytechnet.com/forums/k...avy-paper.html
I added the tape on the drum unit as suggested, it worked for some time but then it didn't. I then added a thin piece of cardboard but it didn't work. I am running DU-104s.
I swapped coronas, drums, put in a new drum, nothing. I also cleaned the surrounding area from the DV unit, no improvement.
What I am guessing the problem is (not all that visible from the photo but is very visible irl) is that the developer is being pulled towards the drum causing the smearing. Why is that happening I have no clue.
Everything is within life, maybe the dv unit is just above 600k. Everything is OEM.
Sent from my Redmi Note 5 using Tapatalk
