Bizhub 227 is not printing bright and clear pages - pages are covered with toner dust
  • Romin
    • Nov 2019
    • 6
    Hi, Bizhub 227 is not printing bright and clear pages - pages are covered with toner dust.
    After new drum unit replacement is it worser then with previous drum unit. Tested with changing DUs.
    On the picture is it demonstrated at the top of page. Bottom is correctly printed page from other printer.
    Any idea?
    Thank you.
  • escalante
    • Sep 2018
    • 115
    Re: Bizhub 227 is not printing bright and clear pages - pages are covered with toner
    good afternoon I make the adjustments when changing the drum unit
    Enviado desde mi Infinix X692 mediante Tapatalk
    • tsbservice
      Field tech
      • 8028
      Toner is compatible cra.? New original drum unit?
      • Romin
        • Nov 2019
        • 6
        Yes, everything is new and genuine.
        • Toxic
          • 698
          Did you use non OEM toner in the past?
          This looks like typically developer contamination.
          Seen this few times when bad toner used, even drum and developing roller was damaged arround only 70k counter.
          I would try to replace developing unit.
          What is machine counter?
            +1 on crap toner.
            Vac out dev unit .. fill with OEM dev powder.. make adjustments.
