konica c308 slow copier and error c-d011
  • enricocopyline
    • Jun 2018
    • 122
    good evening everyone
    I have a copier c308 that starts to go slow then slowly from code c-d011 (hard-disk).
    I install the SATA DRIVER and everything works fine for a few months then the problem returns.
    I have already changed hard drives but I have not solved the problem. What could it be?
  • tsbservice
    Field tech
    • 8020
    Re: konica c308 slow copier and error c-d011
    See this post:
    Originally posted by Albonline
    3 reboots, then will display code it was trying to fix. trouble reset may mode reboot also. i just wait it out then go to service mode. you would have to do a physical then logical format on a new drive .,the 8series acts funny while formatting hdds. logical can take up to 3 retries before it takes.
    BH C368 with C-D011
