Bizhub 754e Service call 2557
  • tomson25
    • 104
    I am getting an error 2557 in Bizhub c754, black toner is not going in the development unit,but hopper is full of toner, while running manual toner add option in service mode ,all 4 colours hopper motors are not working,what could be the problem?
  • escalante
    • Sep 2018
    • 115
    Re: Bizhub 754e Service call 2557
    You have to check the gear play of the transfer belt cleaning unit, Also check the double gear that goes next to the M38 motor
    Enviado desde mi Infinix X692 mediante Tapatalk
    • Zesti
      • Jun 2009
      • 309
      It's 2557 buddy!!!!!
      Check toner shutter, under side of hopper, if its opening. Sometime the DV tank shutter breaks and could not slide back toner shutter and there may be toner over fed in hopper just tap toner shutter side to loosen the toner.
      • tomson25
        • 104
        DV shutter is okay.while running manual toner feed in service mode, hopper motor is not rotating.
        • rrrohan
          • Sep 2011
          • 1977
          If it's not rotating you found the problem
          Sent from my Pixel 4 XL using Tapatalk
