6500 v 6501 Toner?
  • mnorris13
    6500 v 6501 Toner?
    Is there a difference in the toners? Can i use 6500 toner in a 6501?
  • Juggy
    Technical Support
    • Sep 2007
    • 101
    No both machine uses different toner. C6501 use
    TOner type Part number
    TN612 BLACK A0VW150 TN612 YELLOW A0VW250 TN612 MAGENTA A0VW350 TN612 CYAN A0VW450
    • kmcopier
      PSP
      • 183
      Yes you can used it, the C6501 is the same only the
      amount is bigger in the bottle.
      • StormyKnight
        • Dec 2008
        • 50
        So one would assume that the reverse would also be OK?
        i.e. 6501 toner in a 6500?
        If so , might have to investigate the cost per gram (ounce)
        Cheers
        • mnorris13
          It does work with one caviat
          The only thing that needs to be done is cut one nip off the 6500 toner bottle so it keys into the machine. Other than that the difference is nothing. 6501 is completely awesome from color to everything else fixed from the 6500.
          • HORSE
            • Mar 2008
            • 185
            I have noticed a difference in skew between both machines, anyone else noticed this.
            Laughing......
            • mnorris13
              Skew
              We have only noticed skew on some stocks typically Junk 100# 12x18 Gloss cover. Other than that all other sizes and weights are dead on. We eliminated the skew on 100# by going to 13.6 x 19.2 paper size. No place for the paper to go but straight.
              • Setright
                FSS / SPM
                • Nov 2008
                • 247
                mnorris! Nice solution
                May I copy....
                • mnorris13
                  May I copy....
                  Absolutely!
                  • Kenny
                    • Jun 2009
                    • 526
                    Re: It does work with one caviat
                    Hi does the 6501 fit straight in the 6500 then with no mods ?
                    thanks
                    Kenny
                    • BVulgaris
                      • Mar 2012
                      • 32
                      Re: 6500 v 6501 Toner?
                      i have a question about those plastic nibs....
                      which model needs you to snip the nibs off?
                      from what i'm getting is
                      c6501 - no nibs
                      c6500 - nibs?
                      this is worrying because one 6501 model takes toner bottles with these nibs, and the other model we have does not (also a 6501 however).
                      Also, from what I understand. The C6501 has a skew tolerance of 1mm FTB. the C6500 claimed one of around 2-4mm FTB. Much improved on the c6501. I continually hear the c6500 referred to as a copier class machine rather than a digital press which i find interesting (other technicians i work with).
                      • chriseckeard
                        • Jan 2013
                        • 7
                        TN-612 has three tabs and the TN-610 has two. The TN-612 will run in the bizhup PRO C6500 but you need to cut of the middle tab of the three. TN-610 vs TN-612.jpg
                        I just ran a full CMYK set of the TN-612 in my C6500. Supposedly the C6501 has a higher yield per toner then the C6500 so I wanted to determine if it would also work on the C6500.
                        On the same job I was able to get ~40K out of the black with the TN-610 but only ~35K with the TN-612. The color production is equivalent using the TN-612 over the TN-610 though I think the
                        TN-612 was 5-10% lighter which could probably be improved with an adjustment.
                        I needed to increase my yield by 22% to make it worth spending the extra money on the TN-612 over the Tn-610. My results proved that it was better to stick with the less expensive TN-610 Toner.
                        FYI- I do run the DU-104 Drums which are intended for the C6501 in my C6500. They have a replacement interval of 300K rather then the 200K of the DU-102 drums and ~ the same in price.
                        • Kenny
                          • Jun 2009
                          • 526
                          great post chriseckeard !
                          I have just been offered some CPP650 ikon toner which i believe is the same too , any experience ? It is a fair bit cheaper than the konica
                          I will try it on one of our machines in the next couple of weeks
                          • ineo+6501
                            • Mar 2010
                            • 262
                            • Kenny
                              • Jun 2009
                              • 526
