i need schema how to make reset
  • Abdo98
    • Jun 2019
    • 61
    i need schema how to make reset unity drum and develop
    Re: i need schema how to make reset
    Please explain your problem more clearly.
    • tsbservice
      Field tech
      • 8007
      Agree with Phil. Most of Konica Minolta machines have drum and developer chips. You may find some aftermarket chips and even reseters I believe.
      • Abdo98
        • Jun 2019
        • 61
        Possible way to make like in the picture
        • allan
          RTFM!!
          • 5462
          What machine model???
          Whatever
            [ATTACH=CONFIG]50240[/ATTACH]
            Sure with the right:
            Circuit board.
            All the parts and assmbly instructions.
            Or
            Just BUY what you need.
            This thread is done IMHO.
            No pm's either.
            • Abdo98
              • Jun 2019
              • 61
              c224/c284/c364/c454
              • Abdo98
                • Jun 2019
                • 61
                Circuit board.
                Or
                No pm's either.
                I did not understand what you mean
                • allan
                  RTFM!!
                  • 5462
                  c224/c284/c364/c454
                  You can just get aftermarket replacement chips.
                  Or replace the fuses on the chips.
                  Or make a reset tool where you can use glass fuses instead of the SMD fuses.
                  Plugs in like the tool in the picture.
                  Done all of the above with success.
                  The Fuse from a TN512 toner bottle is the same, you can desolder them and solder them on top of the used chip.
                  Whatever
                  • allan
                    RTFM!!
                    • 5462
                    For drum chips the fuse is between pin 1 and pin 3.
                    For developer chips the fuse is between pin 1 and 5.
                    Just trace them back to the front-side PCB.
                    Whatever
                    • Abdo98
                      • Jun 2019
                      • 61
