Staple mistake. C-458 with FS-536SD
  • CP-1015
    • Nov 2020
    • 318
    When stapling, the last sheet remains 1-13mm further to the left than the rest. In the example (see appendix. Arrows at the same time direction of ejection.), 5 sheets were stapled. Please help! Thanks!
  • tech51
    • 846
    I suspect the eject unit has worn out.
    • TPO
      • Aug 2021
      • 12
      If that’s the last sheet, it could also be the paddles needing replacement
      • CP-1015
        • Nov 2020
        • 318
        What exactly needs to be replaced?
        • tsbservice
          Field tech
          • 8013
          A87GPP1702
          • CP-1015
            • Nov 2020
            • 318
            Are the leaves only pushed back by 3 pads?
