Bizhub C224 / C364 scan to email with authentication on
  • alcaster
    • Apr 2019
    • 3
    [Misc] Bizhub C224 / C364 scan to email with authentication on
    Hello
    i have a problem with KM C224 . I have set up scan to email and it works great, but if i enable authorization ( i need to set up ID&print function) then scan to email did not work.
    Firmware is up to date . any idea what might be blocking this function when authentication is on ?
    thanks for answers
  • byronf
    Senior Member
    • Sep 2017
    • 109
    Re: Bizhub C224 / C364 scan to email with authentication on
    Originally posted by alcaster
    Hello
    thanks for answers
    Hi,
    During configuration of user authentication registration make sure that the email field is left blank.
    • alcaster
      • Apr 2019
      • 3
      Great answer . It works . Thank You byronf so much
      • emujo2
        • Mar 2017
        • 1579
        You may be using "use logged in users email address" in admin settings. if this is true and you have not programmed this into each account, then the from address is blank or wrong. E
        • tsbservice
          Field tech
          • 8008
          Too late...already answered.
