Bizhub Pro 920 Fixing Problem
  • potro_salvaje
    • Sep 2010
    • 23
    [Misc] Bizhub Pro 920 Fixing Problem
    Hi everyone
    I have a BH920, that when printed on one side the fusion is correct, but when using the duplex (double-sided), the fusion unit does not fix well on the second side, so it soils the following sheets, the fixing and pressure rollers are new, any suggestion in which would be the problem?
  • scottybbb
    • Dec 2010
    • 126
    Re: Bizhub Pro 920 Fixing Problem
    Make sure both the lamps on coming on. Seen some where only one lamp was coming on. It did not throw an error code.
    • Toxic
      • 697
      After lamps check you could check if the pressure shaft is in correct working position and pressure springs position for lower roller.
      I would also check dipsw for fusing temperature if it is set to lower temperature than normal.
      On what paper type you have problem and is it constantly appear?
      • potro_salvaje
        • Sep 2010
        • 23
        Both lamps are on and it does not throw any error
        • potro_salvaje
          • Sep 2010
          • 23
          Thanks, I am going to check once more the position of the axis and the springs, I already tried raising the temperature with the dipsw, and since this problem appears on A4 and Legal paper
            What gsm paper are you trying to run?
            Is it textured or glossy?
