C6500 - color density problem
  • Toxic
    • 698
    #16
    Re: C6500 - color density problem
    Tulintron, good point , i totally forgot about that step.
    • zmeutz
      • Nov 2014
      • 27
      #17
      Originally posted by tulintron
      Run Factory Default under Recall Standard Data under Process Adjustment.
      Then run test pattern N. 80 and compare the colors
      Do not let the printer adjust. Run the test right after the Factory Default.
      colorful ...
      very nice colors ...
      after gamma adjustment and color registration
      • zmeutz
        • Nov 2014
        • 27
        #18
        I start to think that the problem starts from gamma sensor,
        when I cleaned boards from gamma and color registration sensor can be that I touch this 2 adjustments...
        can I find right position of them, or can I readjust them?
        thanks!
        • methogod
          • Dec 2008
          • 922
          #19
          replace, if cleaning didn't fix. Usually overcompensates the other way when dirty.
          how many test prints did you run before it go lighter, before adjustment? i would have ran a bunch just to be sure it didn't lose density on it own.
          • tulintron
            • Jul 2014
            • 668
            #20
            Originally posted by zmeutz
            colorful ...
            Changing would be the best alternative. However, in the printed tests, it seems to me to have a developer with a shelf life at the end.
            Cyan prints bad colors.
            The yellow background after the adjustments is a faulty gamma sensor characteristic.
            But be sure to change the developers if necessary.
            This sensor strip has an update. Pay attention when making a purchase.
            https://www.copytechnet.com/images/smilies/cool.pngNada como dia apรณs diahttps://www.copytechnet.com/images/smilies/cool.png
            • zmeutz
              • Nov 2014
              • 27
              #21
