TN114 Bizhub 210
  • +ve charge
    • May 2008
    • 87
    TN114 Bizhub 210
    Customer has run out of Toner for his machines , presently only compatibles are available. Import will take another 3-4 weeks. Pls let me know if there is any other original (KM) toner that can be used in this series of machines .
  • DadO
    • Dec 2007
    • 404
    I placed toner for biz 250 on biz 350 and its working same but is toner for 250/350 compatible for 162/163 210/211 i dont know...
    This is a bad try to test this theory but give it a shoot...
    Try to poor an small amount of TN211 on to developer of biz 162/210. When i say "on developer" i mean on magnetic developer roller and not the toner/carier chamber. Place a toner on whole length then roll it a few times.
    Try to make a few copies whit something that has a lot of text so if any abnormality's occurs.... clean the mag roller and wait for toner
    Guys will laugh at this but what the heck, man is in truble.
    • +ve charge
      • May 2008
      • 87
      Thanks DadO..
      Will give it a shot. Seems a much better option than trying some compatible toner
      Hope u don't get flak from the guys for yr advice.
      • ni311
        • May 2008
        • 658
        Be careful, the developers are different, for BH 250 it is DV310 and for BH162/211 it is DV110. I can tell you for sure, is you trying to switch the developers between it won't work. If the developers are different, than the toner are different too, so it might not work.
        Konica Minolta Error Codes - Explanations and Solutions
        • ivovb
          • 695
          My experience with other brands shows that in most cases material and physical characteristics are the same. The only difference is the quantity of product - for example different weight of starter, or shape of toner cartridge. Think about how expensive is to have several lines for different products producing. It is easier to "protect" the price with different shapes, chips, etc...
          Just an opinion.
          BR
          I'll never ask if I didn't check user manual, service manual, parts list, BSI/TNI/TAD... web, existing threads.
          • DadO
            • Dec 2007
            • 404
            I am thinking the same way but wouldnt it be a "fun" for a makers if u would buy 500gr of toner for some expensive machine and pour it in the smaller ones few times?and get extra?
            No one of japans think that way
            p.s.
            Ups i almost forgot to mention. Dont but DONT take any compatible toner for 210/11 if its from mexico! I didnt tested other compatible toners and got nightmare
            • alexxcopier
              • 53
              106B is old variant of TN114
