Bizhub C3350 Reset Administrator Password
  • Distorted Vision
    • May 2017
    • 19
    I get this message when trying to change the administrator password:
    1. Touch Menu.
    2. Touch [Counter].
    3. Touch [Keypad].
    4. Press the following keys in this order.Stop -> 0 -> 9 -> 3 -> 1 -> 7(With this procedure, activate the access lock release timer to start timing.)
    Before trying to reset the administrator password but it does not work. There was no message when entered the above procedure so I'm unsure if the access lock has been released. Should a message be displayed?
  • KMFLT3CH
    • May 2017
    • 242
    No message displays, but you do need to wait at least 5 minutes after step 4.
    You can also try this method:
    In Service Mode press Stop 2 2 2 0 0 to enter Security Service Mode
    Select Administrator Unlocking and press OK
