Hello everybody and happy holidays,
I have an issue with a C7000
the machine has 1,2 M pages, very well maintained overall and recently started having color reg. problems in Magenta and yellow.
The machine completes auto color reg. with out any problem and very small corrections in all colors (0.001 or even 0.000 )
In manual color reg. i get error 5 out of range) with magenta and yellow more than a pixel off.
I have 2 c7000 machines side by side for I swapped transfer belt units with no change at all . the problem stayed exactly the same.
Tried everything else that was obvious (cleaned the reg sensor etc.) with no change.
i am attaching a scan from a print.
the lines above the print is to make clear that the magenta misalignment changes side across the page from left to right,
if you zoom on the photo you can clearly see the magenta pixel on the letters.
