Konica 7020 error code
  • massmar
    HI,
    I have a Konica 7020. It is showing code 'F-35-6'.
    Can anyone tell me what this code is for?
    Thanks!!
    Bye!!
  • TonerMonkey
    • Jun 2005
    • 71
    Fuser irregular temperature - check hot roller, thermostat and thermisters.
    Most likely thermisters.
    • CMB
      KonicaMinolta Tech.
      • Mar 2005
      • 457
      you are correct,it is the thermistors. replace them and reset the code. that would be dip switched 3-1 turn it off.
      • massmar
        I have cleaned thermistors and reset code.
        Now the copy work correctly!!
        Thanks a lot!
        Hi!
