konica c224e fade on top side
  • lazymangr
    • Feb 2017
    • 115
    i got a c224e that all prints are fainted all across on the top side on all colors. i attach a pdf with scanned gradation.ignore the distortion of the banding on the scan, its due to a not so clean scanner. the scan gradiation pages are cut in half and rotated together cause its not that obvious so you see the bottom side compared with the top side. there are new drums, new belt and cleaned laser units with the stick. any thoughts?
    DOC041121-04112021131144.pdf | DocDroid the pdf
  • lazymangr
    • Feb 2017
    • 115
    Re: konica c224e fade on top side
    here are better pics Imgur: The magic of the Internet
    • Gift
      • Mar 2011
      • 2459
      clean the polygon motor / mirrors
      • tsbservice
        Field tech
        • 8053
        +1
        • mp752
          • Aug 2018
          • 1
          清潔清潔電機/鏡子
          +1
          • lazymangr
            • Feb 2017
            • 115
            thanks guys! i will check it and come back to you with results!
            • lazymangr
              • Feb 2017
              • 115
              hi again! it was the polygon motor indeed! a good cleaning and it is good as new! thank you guys!
