BH-C-284e with FS-534SD
  • Hansoon
    • Sep 2007
    • 3384
    How to force the machine to use 1st upper tray for copies only and the 2nd middle tray for prints only? Now everything, copies and prints are landing in the 2nd middle tray. 1st tray is without use.
    Can't find settings for it.
    Hans
  • tsbservice
    Field tech
    • 8013
    Re: BH-C-284e with FS-534SD
    I think there is engine DIPSW for that.
    • elmaligno
      Expert technician KM
      • Oct 2009
      • 302
      Hans
      You can do this in administrator settings.
      Field technician since 1994
      • rrrohan
        • Sep 2011
        • 1977
        Utility
        Admin
        System settings
        Output settings
        Output tray settings
        Sent from my Pixel 4 XL using Tapatalk
        • Hansoon
          • Sep 2007
          • 3384
          Thanks rrrohan,
          that's it!
          Problem solved. Can you imagine that I completely overlooked that menu item? I KNEW it should be there and I KNEW where it must be from the older generation machines but somehow I completely overlooked it, though searching for at least half an hour.
          Boy, am I really getting THAT much of a fossil......?
          Hans
