I Series toner issues
  • mjmjross
    • Apr 2019
    • 11
    [Misc] I Series toner issues
    Hey group,
    We have been having a run on "toner rocks" recently. Only on the I series. The last 2 were C550i and both had the exact same problem. Dumping black on the print glass causing voids on Black only. Printed all 4 gradation sheets and the colors were solid and clean. Then we find the waste auger on the transfer belt all bound up and making noise (on some). On others, the waste was building up on the waste hopper door and not falling into the opening.
    Anyone else seeing weird (black) toner stuff on the I series?
    Thanks!
  • avecosat
    • Jun 2012
    • 305
    Re: I Series toner issues
    Yes, I have some C250i with the problem of noise in the transfer belt by the auger. It is the same as in the C360 series so they told me in KM that it was a problem of ventilation and humidity .. Puff as usual
    • suomi
      • Oct 2008
      • 155
      Toner clogging in the ITBU C360i series
      Cause
      The spring which is opening the shutter of the Waste Toner Box is to long. Therefore
      the shutter is not opening completely.
      • mjmjross
        • Apr 2019
        • 11
        Cause
        We have a new one here and just took the spring out to test it. The door is only spring loaded to keep the customer from dumping waste. I like this suggestion and if I get called back to one of the problem machines, I might just remove that spring. The box opens the transfer belt chute door when it's installed so the spring (and door, IMHO) are not needed!
        Thanks for the reply!
        • suomi
          • Oct 2008
          • 155
          the title could be different. This is waste toner/belt problem.
          there is a new version of the waste toner box
          same number but orange or blue sticker ..
          • tech51
            • 846
            Rather than wasting time and money on a replacement just pop the spring out and cut about 6 turns off it.
            As long as the square opening is fully exposed, that will fix it.
            • tsbservice
              Field tech
              • 8076
              This is already discussed here:
              I-Series belt cleaning units clogging up
              and there:
              C750i
              Look for B0265 post. Agree with others cut that spring.
              • srvctec
                Former KM Senior Tech
                • Oct 2009
                • 827
                and there:
                C750i
                I still don't see how that spring has anything to do with the issue (I could be totally wrong) because it only holds the shutter closed to prevent spills. As long as the mechanical part that shoves open the shutter/door is actually shoving it open, I fail to see how the spring comes into play. If the spring were shorter, it would just make shoving in the aux waste conveyance part, harder to shove in.
                Started in the copier service business in the fall of 1988 and worked at the same company for 33.5 years, becoming the senior tech in 2004 but left to pursue another career on 4/29/22.
                • Drivee
                  • Nov 2020
                  • 322
                  Another problem is transport or storage toner on high temperature. That can be big issue. I measure last air shipment, it was 60C on airport! Plane containers are from aluminum and that metal transfer and generate heat very hast and easy.
                  • tech51
                    • 846
                    • tsbservice
                      Field tech
                      • 8076
                      This.
                      I have made 2 jigs from toothpicks one 52 and one 55mm and now cut this spring as routine.
                      • srvctec
                        • Oct 2009
                        • 827
                        BUT, has enough time elapsed since the modifications to say it definitely fixes it? Not doubting you but we have some machines in the field for over a year and have never had the issue and others that had the cleaning unit plug up within a couple months.
                        This.
                        I have ruler in my toolbox for stuff like that.
                        • tsbservice
                          Field tech
                          • 8076
                          Must be random issue I think. Same as you pull out Wtb and get message about some drum unit incorrectly placed.
                          Ruler is nice but weights more
                          • tech51
                            • 846
                            [QUOTE=srvctec;1995020]
                            • srvctec
                              • Oct 2009
                              • 827
                              OK, now I see what my whole issue was with NOT seeing how the spring could cause an issue. I was going off this post
                              in the thread I started a few weeks ago, and was thinking the spring in question is an extension spring. The one in the photo in the above post is not the one in question and is an extension spring on a different shutter. Soooo, that's why I didn't see how cutting off the end of an extension spring could solve the issue.
                              Fast forward to today when I decided we should go modify the springs on the 3 machines we already had with the issue, and low and behold, I discover the spring in question is a compression spring. Totally different and I completely understand how that could cause an issue. We don't have any of these i-series in the shop to look at and see how it's made and I never paid attention to it when the issue happened and I dealt with it on a service call a couple times.
                              So, we'll be cutting the compression springs for the auxiliary waste toner box shutter on all of these i-series machines as we work on them.
