Konica C6500 Error C-8403
  • zmeutz
    • Nov 2014
    • 27
    [Error Code] Konica C6500 Error C-8403
    Re: Konica C6500 Error C-8403
    How did you clean the sensor?
    • zmeutz
      • Nov 2014
      • 27
        IPA 99%
        YOU HAVE TRASHED THE SENSOR.
        Replace with new.
        NEVER use IPA on sensor.
        Water ..canned air.
        Rookie fuck up.
        • orestesp
          • Sep 2019
          • 222
          *If I remember correctly* Try having the entire ADF assembly lifted at its full upright position when switching on the engine. It should at least let you bypass the code.
          Sent from my Redmi Note 5 using Tapatalk
          • Toxic
            • 697
            You can check wires goes from adf to machine, i have seen it damaged few times and all sort of errors because of damaged/broken wire.
            • zmeutz
              • Nov 2014
              • 27
