Re: C454e print rubbish
lets assume the unknown ID blocked, what are the odds that the corrupted print job still send thru but shows NONAME? (block ID will have to go back and check again, cant really remember what I have set. But I think I didn't turn that on.)
Fax also cant remember, I can confirm even if the Fax module is installed will go and disable it if it was installed. phone line is not plugin. because not using it. I was afraid the on the part internal report. But kind of report could it be?
