Bizhub c658 K toner issues
  • tsbservice
    Field tech
    • 7909
    #31
    Re: Bizhub c658 K toner issues
    Originally posted by JasonSBE
    I did not know. Could you please elaborate?
    31: Y 32: M 33: C 34: K
    • dacam20590
      • May 2019
      • 30
      #32
      on these there are dip switches to reset toner levels.Can you tell me more about how to fix this?
      • JasonSBE
        • Apr 2014
        • 182
        #33
        I looked in the service manual, and switch 33 references expert adjustment and list counter in administrator mode, not toner levels.....
        • tsbservice
          Field tech
          • 7909
          #34
          Dude...it's not even listed in manual, they're DIP SW not Soft SW!
          Just in case you didn't know - on these there are dip switches to reset toner levels.
          • JasonSBE
            • Apr 2014
            • 182
            #35
            [ATTACH=CONFIG]51050[/ATTACH]
            Thank you for clarifying that. After I ran the bottle down and put in a new one, it quickly dropped back to 20%. I took the bottle out, ran the machine until it quit and demanded toner, set the dip switch and rebooted machine. Put the bottle back in and it set back to 100% and is moving down at an expected rate. I'm going to keep testing and make sure that it's depleting normally.
            • Synaux
              • Mar 2012
              • 1224
              #36
              Over the years, I have just learned to not trust the toner level on KMs they just never seem to be very accurate.
              The c650s series were horrendous about not resetting the levels. For a while I would leave a sticky note with the date replaced and meter, but stopped doing that just really wasn't useful. I gave up and just ran them until they were dry.
              Good idea taking the bottle out (I am too cheap to waste the toner though ).
              • Hansoon
                • Sep 2007
                • 3347
                #37
                Not knowing this machine YET, could you please PM me where to find those DIP-Switches please?
                Hans
                “ Sent from my Intel 80286 using MS-DOS 2.0
                https://www.copytechnet.com/images/smilies/biggrin.png
                • tsbservice
                  Field tech
                  • 7909
                  #38
                  Hans
                  Done
                  • Hansoon
                    • Sep 2007
                    • 3347
                    #39
                    Thanks!
                    Hans
                    • JasonSBE
                      • Apr 2014
                      • 182
                      #40
                      Just to update, the toner level was dropping as expected but when I changed the cartridge it dipped to 20% again. Ended up changing the sub hopper as recommended by KM support, and it's been acting right. Put the machine back in service.
