Konica Minolta C3070l - 72-22 Jam
  • Kenny
    • Jun 2009
    • 530
    Hi guys,
    Currently having an issue with a Konica Minolta C3070L, when we try to print A3 100GSM the finisher gets a 72-22 jam and the back end of the paper is rippled. We have ran the same type of paper but A4 and works fine, we have also tried 150GSM A3 paper and works absolutely fine.
    The issue paper is a fresh ream and not damp. I believe there are some tray settings that we can try by changing in the expert adjustment but not sure exactly what settings to change,
    Any helps would be appreciated!
  • Kenny
    • Jun 2009
    • 530
    Re: Konica Minolta C3070l - 72-22 Jam
    Originally posted by Kenny
    Hi guys,
    sorted the issue guys, adjusted to output curl settings worked fine
