Can i set "local" users to print/copy in C458 with AD autentication
  • danifuenca
    • Oct 2013
    • 33
    Hi, my client want set user account in mfp to print/copy for temporary user which has personal laptop to work without join it to domain server. Is posible set mixed config to mfp?
    When i tried set user account in mfp the "edit" button is greied.
    Bizhub c458 with G00-X4 firmware and 4.2 function version set. External server is Windows server 2012 and Single Sing-on configured to users in active directory
  • J_Arnold
    IT Director
    • Sep 2021
    • 87
    Re: Can i set "local" users to print/copy in C458 with AD autentication
    I am speaking about a machine I am not certified on, I would assume you could just add a local driver pointing directly to the IP address of the copier, that might work.
    “First comes smiles, then lies. Last is gunfire."
    • danifuenca
      • Oct 2013
      • 33
      But i need create users in mfp to print because autentication is set to on
      • J_Arnold
        IT Director
        • Sep 2021
        • 87
        Apologies then, I am out of my element. I would assume local printing would bypass user accounts. I know it does on Toshiba devices but again not certified so I would be speaking out of my backside on this product. I thought I could solve the issue without knowledge of the product. Try turning authentication off and see if you can add account, then turn it back on??? I won't be commenting on this anymore since I would be wasting your time.
          • 30760
          Best to get with there IT they can setup an account for that user or setup a guest account in AD
          • J_Arnold
            IT Director
            • Sep 2021
            • 87
            Geez, I overlooked the obvious.
            • danifuenca
              • Oct 2013
              • 33
              No problem. any help is welcome. In KM when you turn on/off authentication any account created before is eliminated
              • J_Arnold
                IT Director
                • Sep 2021
                • 87
                Ouch...that is no fun.
                • danifuenca
                  • Oct 2013
                  • 33
                  I thought that when you configure "MFP + External Server" in authentication method it would allow you to create users on the machine for those temporary users
                  • rrrohan
                    • Sep 2011
                    • 1972
                    Or allow public user
                    Sent from my Pixel 4 XL using Tapatalk
                    • emujo2
                      • Mar 2017
                      • 1579
                      This is an excellent point..it would give you the ability to create non domain users (guests). This only drawback is anyone that can learn these codes can now print, and any paper trail only show that the guest user did the printing/scanning. E
