konica 7145
  • james
    • Jul 2008
    • 21
    konica 7145
    How do you remove the finisher on the machine?anybody?
  • dogsbody
    • Jun 2007
    • 289
    Turn it off,
    open the front door of the finisher,
    at the bottom of the finisher as your facing it you will find a button that when you insert a screwdriver or something silmilar will release the latch at the rear and you can slide it out.
    the FS112 and 114 are reasonably similar to get out, however the 112 will sit flat on a bench the 114 really should have its exit trays removed before removal.
    I have only seen 1 FS113 before but I imagine the RU unit will pull out in a similar fashion to the FS112.
    Never have the power on when refitting the finisher.
    The force will be with you always.
