Bizhub c654e Finisher FS-535 tri fold jamming
  • boogieman
    • Jan 2022
    • 2
    Hi,
    I have bizhub 654e with a finisher FS-535 and recently it started jamming in the SD1 area. I attached pictures were its jamming. It was working fine for long time. I haven't done any tri-fold in the past month or so. Now when I try to do tri-fold, it keeps jamming. I noticed the plastic leans forward too much that the paper goes out of the track. I aligned it back, but it keeps going forward. Once in while I would be able to get one to come out right. Please advice what should I do to fix it.IMG_20220108_170357.jpgIMG_20220108_170329.jpg
    Thanks in advance!
  • tmmdmmm
    • Apr 2021
    • 173
    Re: Bizhub c654e Finisher FS-535 tri fold jamming
    Originally posted by boogieman
    Hi,
    I have bizhub 654e with a finisher FS-535 and recently it started jamming in the SD1 area. I attached pictures were its jamming. It was working fine for long time. I haven't done any tri-fold in the past month or so. Now when I try to do tri-fold, it keeps jamming. I noticed the plastic leans forward too much that the paper goes out of the track. I aligned it back, but it keeps going forward. Once in while I would be able to get one to come out right. Please advice what should I do to fix it.[ATTACH=CONFIG]51370[/ATTACH][ATTACH=CONFIG]51371[/ATTACH]
    Thanks in advance!
    Haven't dealt with it, but do you have an actual jam code? A J##-## at the bottom right corner of the op panel when it happens? Going to be a J72-##. Can check if there's a bulletin on it
    • boogieman
      • Jan 2022
      • 2
      I came back the next day and tried the tri-fold and it looks like it fixed it self. I will update this thread if it jams again with the code.
      Thanks for the help!
