HI all, I have a bizhub c250 that I went to the other day asking to replace belt, I chipped the unit and that reset, but the image was getting typical lines on copies, so I rebooked for a black drum. Before I left I checked error history, it had a lot of p5 and p28, I thought I would check it out when I replaced the black drum. Went back today, put new drum in, still got P codes and the image is gray, not solid black, put old drum back in, solid black image again. I have gone through the manual what to check for p codes, just thought i would put it out there if anyone has any thoughts. Thanks in advance.
konica bizhub c250 p5 p 28 prob
How old is the TX Belt? I assume when you say you re-chipped it, that you did a reset by replacing the fuse?Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
Now into Ip TV KODI Boxes -
I would definitely try a new belt first as both of those P Codes refer to a worn out or damage Belt, and then other things. Try a new belt then refer to the manual and try the next thing on the list.
Keep in mind re-chipping and re fusing is only recommended when everything is working well. re-chipping or fusing will not correct a problem. And will in fact exaggerate a problem if one exist.Online Store is closed. Chip resetting is a thing of the past! Thank you to all my past customers.
Now into Ip TV KODI BoxesComment
