C253 jamming instantly
  • tsbservice
    Field tech
    • 8000
    #46
    Re: C253 jamming instantly
    Originally posted by xdelios
    So finally its working properly.
    To be honest I haven't figured what it was.
    I changed the PS7 with one sensor from the unused tray2 and tried that, it did not work.
    I started following the entire cable to see if there was any weird bends or scratches but still nothing.
    So what I did is completely removed the unit, cleaned everything with q-tips and used a blower to clean the cable pins. I did that last part in the on board connections as well.
    I then connected everything back in and I though that one of the connectors had a bend pin, that could really be my imagination though after spending so much time on it.
    I gently made it as straight as I thought it could be and connected everything.
    It worked...
    I honestly don't think it was that pin though because I am not even sure if it was bent to begin with...
    Anyway it is working and is priting just fine actually, even better than before with the new rollers.
    Thank you everyone for taking the time in this.
    At least I learned half the machine by doing all that and can use that in the future if needed. (expecting a c224e soon)
    Have a great day!
    George
    Good job!
