J10-01
if you push the paper by hand then it works
Ah OK, I recall that you can swap the feed roller rubber with a different one from a production machine to increase the "grip level" - onother hint I got is using the sep roller stuff from older series. I can try and figure out wich customer it was, perhaps I'll find some parts infos.
Edit: 4034015101 (sep roller) / Feed roller mod is not necessary according to my guys
