NIC of Pi-3502 slow
  • Hansoon
    • Sep 2007
    • 3355
    NIC of Pi-3502 slow
    NIC of Pi-3502 slow.
    A have several NIC's for the Pi-3502 (Minolta Di351) which react more slow than other NIC's. Using the same machine with the same controller (Firmware 3.07), just exchanging the NIC, there is a great difference when sending the same PDF or any other testfile. Some NIC's need double the time, some even 3 - 4 times more for printing the same file. All of them having ofcourse the latest and greatest firmware V6.33. Any idea? Shall I replace the electrolytic capacitors on the PWB or might there be another part getting old?
    Hans
    “ Sent from my Intel 80286 using MS-DOS 2.0
    https://www.copytechnet.com/images/smilies/biggrin.png
  • buster68
    • Nov 2008
    • 181
    That's a common problem when the NIC for the Pi3502 is starting to die.
    To my knowledge there is nothing that can be done to fix it, except to replace the NIC, and goodluck finding a new NIC for that model.
    • Hansoon
      • Sep 2007
      • 3355
      Starting to die, yes, but what is detoriating? The electrolytic capacitors perhaps?
      Hans
      • feeder_supply
        only problems... no?
        • Mar 2009
        • 9
        I ignore as dies the pi3502..
        would explain it?
        I did have a pi3502 and the green led blinking in the 5 ports nway switch, it is ok , but then of the first print informe does not do ping, the ip adress does not answer a ping, but whether the test print of copier, but does no print of computer, the netword card is dead..? reset the pi3502.. ok something man help me?
        • feeder_supply
          • Mar 2009
          • 9
          dead pi3502
          would explain it?
          I did have a pi3502 and the green led blinking in the 5 ports nway switch, it is ok , but then of the first print informe does not do ping, the ip adress does not answer a ping, but whether the test print of copier, but does no print of computer, the netword card is dead..? reset the pi3502.. ok something man help me?...
          • TheOwl
            • Nov 2008
            • 1732
            To my knowledge, there isn't much that can be done about the NIC once it starts to fail. These NIC's also have a high failure rate once they start becoming old, unlike other copiers with NIC's that just won't die.
            If it helps, the NIC's for the Pi3502e were built by a company called NetSilicone. Maybe they might have an answer for you.
            • mjunkaged
              • 379
              Hansoon, I believe you are right about it being the electrolytics at fault. If you've got the time, patience, and money, why not?? Let me know in this thread!!!
              You must be an electronics tech. (or ex) to even care! Notice how most of us say "get a new nic"???
              MJ
