Bizhub 658e
  • antone
    • Oct 2014
    • 344
    Bizhub 658e
    Bizhub 658e tray 1,2,3 tray 1 feeds paper no problem! Tray 2,3 feeds one or 2 sheets and jams.Jam code 2004
    Firmware updated
    Replacement of 2,3 feed unit
    Paper stops just before registration unit ! Help!!@
    Sent from my SM-N981U using Tapatalk
  • tmmdmmm
    • Apr 2021
    • 173
    Re: Bizhub 658e
    20-04 is one of the odd ones. Push in the door towards the bottom while passing paper and see if it helps. Try load check for tray 2 vertical transport with the large door (but NOT the 2nd transfer door) cheated and check if pressing down on it slightly causes it to stop.
    Just to edit, the pushing of the door is to test idle tension. About once or twice a month I need to replace/mod the springs for those white idle rollers to give them a bit more pressure. Just did it to a 558 last Friday for T2/3 skew. I've seen it a bit more on the 4 series.
    • Brett GS
      • Jun 2013
      • 154
      Re: Bizhub 658e
      Strip and check the paper feed drive assy.
      2 oneway gears and shaft that they run on can cause that.
      I have replaced a few on 558's in the past.
      • splblazer91
        • Jul 2014
        • 204
        Re: Bizhub 658e
        Paper Feed Drive Assy
